LabWindows/CVI User Group Documents
Preferred Source Code Editor Bracket Styles
The CVI Team would like to get an idea what the most commonly used source code editor bracket styles are. These options are currently available through Options >> Editor Preferences >> Bracket Styles. Please leave a comment on this page describing your preferred bracket styles. For example, the code snippet below is using Flush, Left for both Function Brackets and Statement Brackets:
void main ()
     if (v > 0)
         printf ("hello\n");
Jonathan N.
Comments
ebalci
on
I use the Flush, Left for all bracket styles.
This is the one given as example in Jonathan's post above.
Cheers
S. Eren BALCI
IMESTEK
Mohan
on
My recommendation for default style in CVI: Flush Left for both function and statement brackets.
Personal preference: Uneven Left for both function and statement brackets.
wwilliams
on
Flush, Left (function and statement brackeks).
User002
Not applicable
on
Tim_R
on
Flush Right (function and statement brackets).
Rgulbrandson
on
I use the FLUSH,LEFT for both statements & function blocks.
mjl
on
I also agree on the flush left.  Personally I add a comment to every set so I can easily tell if one has been deleted or moved by mistake.  I know you can use the balance option, but that will just tell you if you have the correct number of brackets, not if they were actually meant to match. IE
if (bGood)
{ // bgood
} // bgood
GarryO
on
I use flush, left for both function brackets and statement brackets.
40tude
NI Employee (retired)
on
Uneven left (function and statement brackets).
Regards, Philippe
Regards, Philippe proud to be using LabWindows since version 1.2
vix
on
  • Flush, Left for function brackets
  • Uneven, Left for statement brackets
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
ebalci
on
It would be great if CVI had a utility to automatically re-format the code with a single key combination according to our style of choice.
(Does it have that already?)
S. Eren BALCI
IMESTEK
JP_V
on
User002
Not applicable
on
Hi Eren,
this utility is missing but has been suggested in the LabWindows/CVI Idea Exchange: http://forums.ni.com/t5/LabWindows-CVI-Idea-Exchange/Auto-Indent-Code/idi-p/1777850 and is under consideration
dcl9000
on
acm573
on
Hola:
Mi estilo de preferencia es el Flush, Left para todo el código. En lo personal por la claridad que brinda al leer el código.
blakney
on
I use Flush, Left for functions and Flush, Right for statements. However, I think Flush, Left for both is a fine default.
RobertoBozzolo
Proven Zealot
Proven Zealot
on
I am using Flush left for function definitions and Uneven left for statements: it permits me to easily detect where every single statement ends up even with several levels of nesting.
carlox
on
I use "Flush, Left" for function brackets and "Uneven, Left" for statements brackets.
Carlo A.
Megaris
ASIC_LabRat
on
Hi John
I guess I am the odd one out...
Flush Left on main...
Flush RIGHT on statements... I also comment the closing brackets
void main ()
     if (v > 0)
         printf ("hello\n");
         } // end if v > 0 begin else
     else
          }// end else v <= 0
} // end main
is NI looking at making some mods to the editor... I definitely like the look and feel of the NotePad++ program if anyone has tried it in the C language style.
The interactive brackets highlights are nice as well as the alignment bars...
Reg
Chipb
Contributors
