NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
jdubs
Auto Indent Code
Status: In Beta
by Member jdubs on ‎11-16-2011 12:34 PM
While developing code, having correct indentations is very helping in making sure you have all the right brackets and to see where your structures are nested easily.  Sometimes, whether by copying and pasting or just rapidly getting out a section of code, a whole segment might have incorrect indentation, which is tedious to correct.
This is where an auto indent tool could be a big time saver.  From somewhere like the Edit menu, where similar functionality is located in other development environments, you could select Format Selection to do a highlighted section or Format File to do the whole file.  Then, CVI can format the tabs for you:
Although this is a simple example, auto indent becomes even more useful when you have multiple nested structures and decide, for instance, to add or remove another nested loop.
Status: In Beta
Comments
by Active Participant LuisG on ‎12-13-2011 11:20 AM
Status changed to: Under Consideration
by Member SteveD123 on ‎01-19-2013 08:27 AM
dubs, you state that "a whole segment might have incorrect indentation, which is tedious to correct". Are you aware of a programe called "Artistic Style" that will do this for you? It can be found at http://astyle.sourceforge.net/ It is under the GNU lesser GPL V3, so it could be included in a CVI distribution. From the website: "Projects that use Artistic Style do not have to make the source code available. If Artistic Style itself is modified, however, the modified Artistic Style source code must be made available."
by Active Participant JonathanN on ‎03-27-2013 11:49 AM
Status changed to: In Beta
About LabWindows/CVI Idea Exchange
Do you have a feature idea for how to improve LabWindows/CVI? Submit and vote on ideas now!
  1. Browse by label or search in the LabWindows/CVI Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. You should submit a separate post for each idea. Watch as the community gives your idea kudos and adds their input.
  3. Give kudos to other ideas that you would like to see implemented!
  4. NI R&D will review ideas that have been submitted and update the status.
Note: the LabWindows/CVI Idea Exchange is not the appropriate forum to submit technical support questions.
The LabWindows/CVI R&D team is committed to reviewing every idea submitted via the LabWindows/CVI Idea Exchange. However, we cannot guarantee the implementation of any LabWindows/CVI Idea Exchange submission.
Idea Statuses
Top Kudoed Authors
User Kudos Count
6
5
4
2
2
