zero string in array
hellow,
i have some problem,
i have 1D array of string, i need separated string with zero value and do new array which contained only no-zero values,
is it possible
thanks
Message 1 of 15
(5,701 Views)
Everything is possible, but your description is incomplete.. A string is not numeric, so do you want to remove the elements taht have the character zero or do you want to remove elements that have empty strings, or both?
What have you tried so far? There ae plenty of examples posted in the forum to do this. Is this homework?
Message 2 of 15
(5,676 Views)
thanks altenbach,
I need remove elements with empty string and do new array without empty string (in attachment a describe this...)
Message 3 of 15
(5,658 Views)
Try this, credits for DFGray: http://forums.ni.com/t5/LabVIEW/Dr-Damien-s-Development-Memory-Allocation-in-Loops/td-p/1075712
You probably could put Trim Whitespaces for empty strings with 1 or more whitespaces before.
Message 4 of 15
(5,649 Views)
If you have a recent LabVIEW version, all you need is a conditional output tunnel as follows:
Message 5 of 15
(5,635 Views)
Please i have version of labview 10., could you convert it    thanks
Message 6 of 15
(5,631 Views)
I have already uploaded the VI with your version of LV.
Message 7 of 15
(5,623 Views)
unfortunately, but when i try open it, it talk me (it is verion 12 ???)
Message 8 of 15
(5,617 Views)
What is the purpose of the outer case structure?
Here's a much simpler version of the same (LV 2010).
Message 9 of 15
(5,616 Views)
If you feel like my version is still a little complicated, please vote for my idea here. 😄
Message 10 of 15
(5,611 Views)
