"new byte" conversion from .net into Labview
I'm currently working on a Labview / .net program which involves copying c# code and making it usable in Labview.
I'm stuck trying to convert three numbers (A,B,C) into a 1D array, and keep coming up with an error. I'm using build array for each of the elements to get the 1D array, but I'm sure I must be doing something wrong. The code looks like:
new byte[A * B * C]
The three numbers are in the format of long 32-bite intergers, but the input for the reference is unsigned 8-bit integer.
If anyone could help me figure out what I'm doing wrong it would be greatly appreciated.
Ross
(3,065 Views)
Actually, if I'm not mistaken, this simply allocates a byte array of A * B * C elements. So the LabVIEW equivalent would be to create the product of A * B * C and simply wire this number to the Initialize Array node.
Rolf Kalbermatter  My Blog
(3,053 Views)
Thanks a lot Rolf - my program is now up and running!
(3,019 Views)
