zero crossing detector in software
I have an analog input read from a PLC which is copied into a variable. whenever it crosses a particular value x, I want to set a variable. Something similar to a zero crossing detector in hardware. Is this possible in Labview?
Thanks!
(5,256 Views)
What exactly do you mean by "crosses particular value"? Do you want to trigger a signal whenever your analog input reaches or goes high than that particular value?
You might want to use "equal to" function in comparison palette.
(5,247 Views)
the problem with using 'equal to' is , the signal has to be polled in a while loop and the while loop requires a delay and if during the delay time the signal crossing happens the program will miss to detect it.
I am looking for something similar to a microcontroller interrupt. when an event happens, a signal is triggered, we dont have to poll for it continuously.
(5,232 Views)
Use event structure to trigger another event whenever an input changes it's value. If it is boolean ( High or Low ) then use " Boolean Crossing ptbypt".
(5,225 Views)
What is the sampling rate of your acquisition? Use "Timed Loop" to acquire every sample without missing one. And then inside that loop use event structure to monitor for signal change and then trigger an event based on that change.
(5,217 Views)
Use a >? comparison with the analog input wired to the top terminal and the value of x wired to the lower terminal. The output (boolean) goes to a shift register. Compare the previous result (left terminal of shift register) to current value (output of comparison). If they are different, you have an "x-crossing." If you only want crossings in one direction, the logic is slightly different.
Lynn
(5,188 Views)
