ctrl val set invoke node & value change event
I call the "Ctrl Val.Set" method on a boolean of a separately running VI, and there I expect a value change event in the event structure. The value is changed, but no event is triggered. How can I enable a trigger?
Message 1 of 8
(7,342 Views)
The "set ctrl value" method was introduced way before the event structure, I believe it's for this reason that you can't expect it to fire an event (maybe I'm totally wrong on this though).
Anway, if you use this method, the event structure will not be able to catch the event, what you have to do it to open the reference to the target control and then use the "Value signaling" property, it's just a little but more code but then the event structure will be able to catch the value change event.
Hope this helps
Epictetus
Antoine Chalons
Message 2 of 8
(7,336 Views)
Hi Titou,
yes, this is exactly what I do now. I hope we get a feedback from NI, whether is it a bug or a function.
Message 3 of 8
(7,328 Views)
@mitulatbati wrote:
Hi Titou,
It is expected behavior.  Events for FP objects are created only by user interaction with the lone exception being the val(signaling) property that was introduced for the express purpose of programmatically generating val change events.
"Should be" isn't "Is" -Jay
Message 4 of 8
(7,325 Views)
I think Jeff is right, and maybe it was not clear from my first sentence but I think it should remain like this, the "set control value" method should not fire an event.
No way NI will accept this as a bug.
Question is do you know how to get the control ref so you can use then the property node "value signaling" to fire your event?
Epictetus
Antoine Chalons
Message 5 of 8
(7,317 Views)
Yes of course, I program LabVIEW for 8 years 😉
Message 6 of 8
(7,312 Views)
oups.. sorry, no offense of course 🙂
Epictetus
Antoine Chalons
Message 7 of 8
(7,304 Views)
Do you mind putting an example of this up?
Message 8 of 8
(6,647 Views)
