‎06-26-2018 03:18 PM
I have AVC (H264) file.
DivX/KMP players reads it normal.
I need to analyze this file in LabVIEW.
But when read I get -1074395970 error (no codec).
Win 7 (win 10 on customer PC)
LabVIEW 15 (32)
I have installed
C:\Program Files\video\x264vfw64\x264vfw64.dll
and
C:\Program Files (x86)\DivX
and "get codc names" returns
What I need to install / configure so that LabVIEW can read this format?
‎06-27-2018 01:40 AM
@Artem.SPb wrote:I have installed
Try installing 32-bit version of this codec.
‎06-28-2018 04:20 PM
The LabVIEW Tools Network (VIPM) contains a "Multimedia for LabVIEW" library that contains the 32-bit and 64-bit versions of m4LabVIEW and purports to allow you to read/write MPeg4 (h.264) files. I haven't tried it. It isn't free, but a Run-Time license doesn't seem very expensive.
If this works, please report this here as I'm sure others will be very interested. I might even spring for it, myself ...
‎06-29-2018 03:46 PM
@PiDiTry installing 32-bit version of this codec.
Thank you.
I installed the codec from here https://sourceforge.net/projects/x264vfw/
and now the file is successfully read.
‎06-29-2018 03:53 PM
I installed this pack, but when tried to open my file, I've get error 1430:
g_StaticWrapperPath.vi<APPEND>
<b>Complete call chain:</b>
FileReader.lvclass:FileRdrNew.vi
FileReader.lvclass:PAOpenInputFile.vi
Untitled 2
Because the installation of 32-bit codec works, I will not try this pack more.
