write to string spreadsheet file.vi
i am using Write to String Spreadsheet File.vi
I want to create a spreadsheet to a folder.
but if the file name is already exist,
instead of it prompting me to overwrite it.
Can it automatically rename it for me? how would i do that..
if lets say i have
SN_50000.xls
and i want to create SN_50000(2).xls if SN_50000.xls is already created.
i dont want to replace...
Krispiekream
Message 1 of 16
(5,748 Views)
No, it cannot "automagically" rename it for you. You have to do that yourself. Use the Check if File or Folder Exists VI to see if the file exists. If so, change the name. Simple.
Message 2 of 16
(5,747 Views)
Accepted by krispiekream
Take a look at the attached vi, this is one that I have used before.  I believe it will suite your needs.  Let me know if you find any mistakes or implement improvements.
Message 3 of 16
(5,742 Views)
thank you!!!!!
Krispiekream
Message 4 of 16
(5,736 Views)
i am using labview 7.0 and i dont see the "CHECK IF FILE OR FOLDER EXISTS" function..???
Krispiekream
Message 5 of 16
(5,726 Views)
You can use the OpenG version (look here).  You will have to download and install the VI package manager
Message 6 of 16
(5,681 Views)
this there another option beside installing openG?
It doesnt seems to get installed on my computer..
Krispiekream
Message 7 of 16
(5,668 Views)
I have attached the OpenG VI for your use.  You should go to the OpenG forums and figure out why the install does not work.  I think you would find it to be a benefit as there are many nice VI's that are well written and well tested.
Message 8 of 16
(5,663 Views)
What is not getting installed? VIPM or the individual packages? LabVIEW 7 is supported, but in order to run VIPM you need to install the LabVIEW 8.2 Runtime. I'm guessing that's your problem.
A simply alternative is to use the File/Directory Info function and look at the error code. If you have an error and it's error code 7 it means the file doesn't exist. If there's no error, the file exists.
Message 9 of 16
(5,660 Views)
What Smercurio wrote is essentially what the OpenG VI does.
Message 10 of 16
(5,658 Views)
