03-04-2009 02:22 PM
What is not getting installed? VIPM or the individual packages? LabVIEW 7 is supported, but in order to run VIPM you need to install the LabVIEW 8.2 Runtime. I'm guessing that's your problem.
A simply alternative is to use the File/Directory Info function and look at the error code. If you have an error and it's error code 7 it means the file doesn't exist. If there's no error, the file exists.
no...the VIPM is installed in the desktop..but the individuals packages that i download into the VIPM won't install in my labview 7.0..
VIPM will only work with Labview 8.2 Runtime or compatible or else I won't be able to use use VIPM.
but, i'll try going looking at the error code 7 and see if that will work..
thank you guys for helping me out..
03-04-2009 03:38 PM
there server is down or something..
i can't install the pacakges in..
it would be easier if i just download to my desktop first and install it after..but the VIPM download and install all at once..
03-04-2009 03:43 PM
File Exists__ogtk.vi (18 kb)
the file you give me can only run in labview 7.1 can you make it for labview 7.0?
03-04-2009 03:46 PM - edited 03-04-2009 03:48 PM
Really, now... It's not that difficult to code it up yourself, as I already explained what you needed to do. The actual OpenG function does this:
03-04-2009 04:16 PM - edited 03-04-2009 04:24 PM
i tried using file/directory info function..
the only thing it give me is the directory info...
the number of files in the directory
and going with the error code...
i recieve no error..
i'll play with it some more..
03-05-2009 05:54 PM
yeah..so i managed to do it..
there is a lot of ways to do it though.
i didnt use the "file or directory info" function..
