write output array results from mathscript
Hi there, i want to write the output array results from my mathscript but it turned out that only one data was written.
My question is, do i need to include a while function in my mathscript in order to output more than one data.
I have continnuos signals (array) as input for the mathscript.
dave
(2,656 Views)
Hmm, well you can definately output an array from a Mathscript node. My guess is you haven't configured something correctly either for the output or more likely in your script. Try looking through these:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x30HCAQ&l=en-US
http://zone.ni.com/reference/en-XX/help/373123C-01/lvtextmathmain/ms_passing_data_lv_mathscript/
And can you post a simplified version of your Mathscript node in case there's anything obvious as to why you're not getting an array out?
--Ryan S.
(2,613 Views)
