while loop synchronous operation
I have created a vi where it has to acqire data over ethernet parallely (using two while loop) and display those data . but i m unable to do so because both the loops are not running simultaneously . Somebody please help me out . VI is attached
(4,620 Views)
Accepted by Nepla
Of course they don't run in parallel. You don't understand the basic paradigm of LabVIEW - dataflow. You've forced the top loop to execute after the bottom loop because you wired the controls in the bottom loop to the top loop.
(4,616 Views)
Thanx a lot !  How to control both the loop with single control action (STOP Button )
(4,603 Views)
An easy way is to simply use a local variable. The mechanical action cannot be latching though so you would use a another write after the loop finishes to set the value back to false. There are other, more sophisticated ways without using a local but this will get you going.
(4,599 Views)
(4,598 Views)
Done Sir, Thanx a lot for your help!!!!
(4,586 Views)
