what error is this ?
I've managed to correct the problem, I explain how I got rid of it, in case someone stumbles upon this error.
The error wasn't possible to locate most probably because my SQL ODBC Driver was outdated/missing. I was still able to write in the database, but the error indentification wasn't correct anymore.
I upgraded the SQL ODBC Driver to mySQL 5.3 and was then able to locate the problem: Two of the parameters took the value NaN returned by LabView but which is not interpreted by SQL so it was truncated in the command...
Message 11 of 13
(1,080 Views)
Thanks for posting the solution you found!
Message 12 of 13
(1,059 Views)
Thanks boontart I also solve my problem ....................
Message 13 of 13
(1,026 Views)
