waveforms
hey guys,
pls check this file and guide me what should I do to show input and output waveforms in a single graph as I want to compare both of them? I tried to create the array but it couldnt worked. I also want to try different waveforms at input(sine, square and triangle). Pls guide me. As I am new to labview. Pls reply me soon
Jinal....
(3,298 Views)
When you go to the diagram, make sure that context help is turned on and move your mouse over the chart indicator. It will explain how to do multi plots. All you have to do is bundle them together. If you want to output different types of signals, you could use a case statement with different calculations in each.
p.s. Your current diagram is a mess and you might want to spend some time cleaning it up.
(3,285 Views)
could you pls let me know what is wrong with the code and how can I improve that?
(3,260 Views)
You should look up the style guidelines in the on-line help. You want wires/data to flow from left to right for one thing. The wires should be as straight as possible. You also want to avoid wires going underneath other objects. Your general error handler VI looks like it is inside the while loop but it's really not.
(3,255 Views)
