08-02-2007 01:07 PM
08-03-2007 01:08 PM
Jinal,
This would really depend on the frequency of the signals that you input/output and the DAQ device you are using. Usually, you would read your output back into an input channel, but, of course, there will be some degree of latency between your output and input from your external circuit and from the fact that the signals will be multiplexed in (unless you have a simultaneously sampled board).
I would check out example finder for the synchronization examples in Hardware Input Output -> DAQmx -> Synchronization -> Multi-Function as a starting point.
Craig D
