want to continuously read position from a stepper motor while moving it
I'm writing a LabVIEW 7.1 application that involves sending move commands to a ThorLabs 3-axis translation stage. This is being controlled via stepper motors which in turn, are controlled via a BSC103  controller (USB link). I can send move commands to the unit fine, and also read position. What I would like is to have a real time display of position, while carrying out move commands.
In previous programming work I've been involved in, this kind of sounds like a detached process kind of thing. Can this be setup with LabVIEW 7.1?
Message 1 of 8
(5,169 Views)
Search the Labview examples for the "Robot.vi"
I think that is (or something similar), what you want.
Message 2 of 8
(5,153 Views)
Had a look at the robort.vi. Very impressive. Through that, I've been able to get my application to run with continuous update of stepper position.
Thanks.
Message 3 of 8
(5,132 Views)
Hi there. I know this is an old thread but I would be interested in knowing what NI hardware you used to send the move commands (pulse trains), to your 3 axis driver??.
Message 4 of 8
(4,791 Views)
Looks like datalog hasn't 'logged' in in nearly 4 years.
I suspect from his initial post that he was not using any NI hardware but rather sending commands and recieveing data via the USB connection to the drive.
-AK2DM
Message 5 of 8
(4,783 Views)
Sorry to hijack an old thread... I was trying to find the "robot.vi" you mentioned, and I couldn't find it. Does anyone know how to find it, or has a copy of it they can post?
SM
Message 6 of 8
(4,656 Views)
Hi.
The Robot.vi is not to be found in the Example finder.
There are some good vi's located in the folder "Robotics -> Control and simulation".
Go through the simulations and find the one which fits your project best.
I have attatched a picture showing the example finder.
I would recomend looking at "SimEx Robot Differential Steering.vi" or " Quadcopter Dynamics and Control.vi".
\\ mBaltzer
Message 7 of 8
(4,624 Views)
Thank you!
Message 8 of 8
(4,593 Views)
