wait on edge timeout rio
I'm working in development mode emulating a 7841R target. Trying to set up a function that waits on a digital line to change I noticed, that the "wait on..." functions always returns immediately. This is probably due to the undefined or arbitrary input state.
Then I set up a test bench vi to simulate i/o. I added an i/o item name case and cases for every node or element type. But the VI doesn't seem to be called when I run my emulation code (however the run arrow does change to some sort of "ready" or "waiting"). Setting probes inside the simulation i/o I cannot observe any execution.
What am I doing wrong?
Kind regards,
\Ulli.
(2,522 Views)
Hello Ulli,
Find attached a link to a tutorial about Efficient Development and Debugging with LabVIEW FPGA.
https://www.ni.com/en/support/documentation/supplemental/21/testing-and-debugging-labview-fpga-code....
Search in the LabVIEW Help for the following topics, you’ll find a detailed description about the debugging technique on a FPGA
-Debugging FPGA VIs on a Development Computer
-Creating Test Benches to Debug and Test FPGA Vis
-Tutorial: Creating Test Benches
Kind Regards
Ulrich
AE NI-CER
(2,501 Views)
