vibration acquisition
hi everybody.
Is there a way to accelerate data acquisition with an accelerometer. When i ran my vi the loop should iterate one a second. But as i have other programs running, when i count the number of data i should have, i notice that there is some missing points the file written from the acquisition. I'm using a NI9234 module with a pcb 100mv/g accelerometer.
Anyone has a clue how we can accelerate the loop time iteration to have exactly the desired data even with other tasks running after the acquisition.
Regards.
(2,153 Views)
Hi M.ezzakkar,
You're already half-way to this, but you might want to read about Producer/Consumer design.
This would allow you to remove all of the local variables, which will perhaps help a tiny bit with speed and a lot with reliability.
Consider just enqueuing the latest data and doing all of the "graphing" in a Consumer loop below.
I'd also suggest using the DAQmx nodes rather than the DAQ Assistant - in this case it probably isn't the critical problem but it will make your code easier for others to read at a glance.
It also gives more control in case you need to try tuning it in order to optimize throughput etc.
You can read some starting tips here: Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications.
GCentral
(2,129 Views)
hi
(2,097 Views)
