1D array of booleans in source of boolean type
Good morning all
how can we transform a source of type 1D array of booleans into source of type booleans?
have a good day
(2,118 Views)
@thib101200 wrote:
Good morning all
have a good day
That doesn't really make sense.  It's like saying, "How do I transform a crate of apples into one apple?"  What is it that you are really trying to do?  In other words, "Why is it that your data is an array of Boolean data type and whatever is operating on that data expects a single Boolean value?
Bill
CLD
(Mid-Level minion.)
(2,109 Views)
Worse than that, because the end is in plural, so:
"How do I transform a crate of apples into apples?"
Makes absolutely no sense!
First we need to define what "transform" should mean here. Too vague! Then attach some code containing the incompatible source and sink you want to connect together.
  • You can use index array resized to a sufficient number of outputs and wire a scalar boolean to each.
  • You can autoindex on a FOR loop and get one boolean in order with each iteration.
  • You can use array to cluster to convert to a custom cluster with the same number of booleans.
  • etc etc etc.
(2,062 Views)
