vi works exe not working throwing an error
Message Edited by mathan on 07-24-2008 08:03 AM
Message 1 of 10
(3,808 Views)
Hi mathan,
to help you with that one, we'll need to see the code.  At least Co1.vi & doctor.vi.  Can you post them?
R
Message 2 of 10
(3,804 Views)
Somewhere in your code you open up the front panel of the VI. Unfortunatly this is removed by default during build.
Modify your build settings to not remove the FP.
Ton
My LabVIEW Ideas
Message 3 of 10
(3,796 Views)
wow..  good catch TonP!
Message 4 of 10
(3,782 Views)
Dear Ton,
How to do this ? Give me a screenshot please.
Mathan
Message 5 of 10
(3,750 Views)
Accepted by Mathan
There are several ways:
  • Use some code that forces the compiler to include the FP, for instance a property node to a control.
  • Set it explicitly in the build settings (preferred):
Assuming you use 8.5
Ton
Message Edited by TonP on 07-25-2008 07:44 AM
My LabVIEW Ideas
Message 6 of 10
(3,746 Views)
Dear TonP,
But that option u told was disabled by default. see here..... Yes am using LV8.5
Mathan
Message Edited by mathan on 07-25-2008 01:21 AM
Message 7 of 10
(3,743 Views)
You're showing the dialog for the Startup VI. The front panel of the Startup VI can't be removed.
Edit the properties of the SubVI (doctor.vi).
Message 8 of 10
(3,731 Views)
Vow.... That's the trick. Good catch dan_u....
It WORKED.
Thanks a lot.....
Mathan
Message 9 of 10
(3,726 Views)
I'm glad it works.
Thanks to Ton who localized the problem Smiley Happy
Daniel
Message 10 of 10
(3,718 Views)
