variant to data In QMH remain empty
hallo,
I am working on a logging module.the software uses QMH architecture.
the project has a sent Log.vi as below. this is subvi is called whenever i need to log the status.
In the logging module, i used a deque element and in the update log case, i use a variant to data for logging the data.the screenshot is attached below.
the data is empty. why?there is no error but the log data is completely empty with headers
(1,096 Views)
No one can debug pictures.  Post your actual code.
(1,064 Views)
I agree with Paul that it is difficult (and usually not worth the effort) to debug "pictures" (even if they are legitimate VI Snippets, which yours don't seem to be).  However, I noticed that the dequeue (not the spelling -- the last "ue" is important) has Cluster unbundle, suggesting there may be multiple Queues, one of which is called "logging".  If you enqueue into a Queue contained, for example, in a Cluster element named "UI", say, and try to dequeue from another Queue named "Logging", you might not get much useful information.
(1,046 Views)
Without seeing code I CAN guess that either your message has a typo or, you lost the refnum in an unwired case.
"Should be" isn't "Is" -Jay
(1,017 Views)
I would guess that a Break point and Retain values will quickly reveal the truth. You've probably misspelled "Update log" or similar in your Enqueue.
Qestit Systems
Certified-LabVIEW-Developer
(988 Views)
That should be "Update Log" the case structure is not set to ignore case.  (I think that you exactly duplicated the OP's most likely source of error) 😀
I double the Kudos if he has a "Developer Error, default" case in the actual code to catch message typos.
(972 Views)
That's why i prefer Enums as Commands. 😄
Qestit Systems
(963 Views)
