updating the value from call library function
Hi everyone,
I am facing a problem configuring a CLF in Labview 2015-64.
I have a dll which is written in C++ (code is available) and need to be called in Labview for indication purposes. The dll should be called once and I need to keep reading the result as it is being updated.
Hier is a sample code in C++, and the goal is to read the sum pointer in LV as it is being updated in dll: (correct me please if the C++ code should be changed!). dll is also here attached.
__declspec(dllexport) void test_sum(int iteration, int waitTime, int *sum)
	for (int i = 0; i < iteration; i++) {
		*sum = i + 1;
		Sleep(waitTime); //wait in ms
Here is the LV code I have made, it does not crash but just gives me only the last value (here 20). But I expect to copy the memory from the pointer every 2ms in the while loop and showing me the values from 0 to 20!
Any help or hint is greatly appreciated.
(3,251 Views)
Why is the size 8? An I\U32 is 4 bytes?
You might try not running the dll in the user interface thread. It might block the UI thread regardless the Sleep.
(3,244 Views)
Accepted by topic author Skydive
You can leave the "might" away. Make it:
You MUST NOT running the dll in the user interface thread. It WILL block the UI thread regardless the Sleep.
Rolf Kalbermatter  My Blog
(3,226 Views)
Hi Rolf and wiebe,
thank you for the quick response. That was totally correct.
I had this problem before but apparently lessons not learned 😞
Hopefully everything will work when I change it to U8-2D array.
Thanks again.
(3,199 Views)
