update from excel when a button is pressed
hai guys,
 Would like to know if itz possible to update only certain row of the excel sheet to Labview to be processed.
Example
we enter value in column A1 B1 and C1 in an excell sheet ,can we make programme to detect certain command ( update) button in excel. Only when we press the update button the values will be updated in labview
hope my explanation is clear.
thanks
regards
Shamaran
(2,530 Views)
Your question is not clear. Do you
a.) Want a button in excel that when pressed will export data to LabVIEW
                               or
b.) Want a button in a LabVIEW VI that when pressed will retrieve data from an excel spreadsheet. (.xts)
Please also include what version of LabVIEW and Excel you are using.
Do you have the Report Generation Toolkit?
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,521 Views)
http://zone.ni.com/devzone/cda/tut/p/id/5719 discuss on how to call LabVIEW VI from Excel.
Then, you can update data from Excel to global variable in this VI, and update to desired VI.
(2,491 Views)
