01-25-2007 10:44 AM
01-25-2007 01:55 PM
I only briefly skim the subjects of the forum threads, and regretfully I missed this one until now.
Some questions for anyone experiencing this problem:
I'd like to do my best to help anyone experiencing this, but it might be difficult if we can't isolate the cause, and since I have never seen this happen personally, I'm having trouble thinking of what might be causing it.
01-25-2007 02:07 PM
01-25-2007 02:57 PM
I am the originator of this subject. It seems that I am not the only one who experienced this phenomenon.
I am working on another machine nowadays, and I don't have recent experience with this problem.
I did have administrator rights to all files ton the C-drive.
I did not monitor the contents of the LabVIEW Data\LVAutoSave directory both before and after selecting Recover and Discard on that VI.
If, in the future, I go back to that particular machine, I'll check on it.
01-26-2007 08:00 AM
I understand you probably have better uses for your time, but if you'd like to try to reproduce this on your machine, try the following:
If you get a chance, let me know what you find, thanks!
02-08-2007 09:43 AM
Jeff,
I had the opportunity to simulate failure as you described it. I used the "Text Report Example.vi" and added a knob to the front panel.
After restarting LV8.2 there was an autorecovery window as expected.
I chose "cancel" and proceeded with
I closed
The LVAutoSave folder had an archives sub folder with a zip file in it.
When I reopened
I guess I’ll have to observe the content of this LVAutoSave folder if and when I have another spontaneous malfunction.
I repeated this by forcing the power out.
I did not see any unwanted autorecovery attepts.
Maybe the large size of the source code I was working with when the original problem was observed has to do something with it?
Anyway, I do not have any problems now.
Thank you for your time.
02-09-2007 07:22 AM
Thanks for the feedback.
I wouldn't expect size to be a factor, but hey, with bugs, sometimes you encounter things you don't expect. 🙂 At least this one is harmless with an easy enough workaround.
I'd be more inclined to think it would be related to how you respond to the dialog, but if you also were hitting "Cancel" the time you saw the problem, then I don't have a good explanation yet.
Hopefully if someone else sees this they'll find this thread and add their experiences, and maybe I'll see it soon enough to get some feedback from them while the situation is occurring.
03-01-2007 01:38 AM
03-01-2007 08:24 AM
Hey Ton,
Thanks for the feedback. I am not sure what would be causing these files to get into this strange state. I presume that these files will not go away no matter how you respond to the recovery dialog either, correct? Various things that should remove those files are:
So we've determined that even after restarting LabVIEW these files are not deletable. To resolve the problem, you might try restarting the computer. Of course then we might not be able to reproduce it anymore.
Is there anything that struck you as particularly odd about the situation in which you originally ended up with these files to recover (crash / power failure / etc), or the subsequent initial recovery process? Or did things seem to go normally? If you don't remember that's ok, but I'll take whatever information I can get. 🙂
03-02-2007 03:11 AM - edited 03-02-2007 03:11 AM
Message Edited by TonP on 03-02-2007 10:28 AM
