undock/dock a tab page
I know this is somewhat a silly question.
In my wildest imagination, will it be possible to undock/dock a page from a a tab control. Of course I could not find anything from the property node or invoke node to achieve this.
Message 1 of 10
(6,252 Views)
How many Kudos would giving you a hint to realize that dream be worth?
Ben
Message 2 of 10
(6,243 Views)
In your wildest imagination?  Sure!  Smiley Happy
In the real world?...   Not so much.  Smiley Sad
Perhaps a scripting expert will chime in...
Message 3 of 10
(6,238 Views)
Accepted by ade77
Ben
Sometime I guess I can be a little TOO subtle.
CLICK HERE to see a working demo.
Ben
Message 4 of 10
(6,231 Views)
Ben,
my wildest imagination has been realized. I would have given you 10, 000 kudos, but unfortuantely I am restricted to 1.
Now I believe there is nothing impossible with LabVIEW.
Thank you vey much.
Message 5 of 10
(6,217 Views)
I need a memory upgrade.  I downloaded Ben's docking_example code a long time back but it totally slipped my mind.
One more Kudo for you though!
Message 6 of 10
(6,209 Views)
You don't need scripting as much as some low level window management with respect to hosting windows in a VI front panel (subpanels) and free floating windows (just the VI).  I might add a host with subpanel for the free floating window, as well, just to encapsulate the dock and undock behavior, but Ben's example certainly covers the basics.
Message 7 of 10
(6,206 Views)
I concidered that but ruled it out becuase I had a self-imposed requirement that the code used in the sub-panel would not have to change as a result of being used in an un-dockable page.
What I have concidered but never got around to was wrapping it up in an XControl and exposing a method to define the VI to run in the sub-panel. THe XControl would also handle the tedious work of sizing and postioning the objects at development time.
I would be very interested in other commenting on how to decide when to close the template. I resorted to polling the state of the calling VI since I discovered no better method of ALWAYS catching the caller going idle.
Thank you!
Ben
Message 8 of 10
(6,161 Views)
@ade77 wrote:
Ben,
Thank you vey much.
I would be very happy getting another Kudos on the post with the example. Smiley Wink
I am glad it helped.
Have fun!
Ben
Message 9 of 10
(6,159 Views)
I didn't look at it in a long time, but the code here might help as an example - http://lavag.org/topic/5099-xcontrols-as-childwindows
___________________
Try to take over the world!
Message 10 of 10
(6,142 Views)
