typedef won't update
I have a state machine (which has always worked), and I wanted to add an extra state.  But when I try to update the enum typedef, I can't.   If I open the typedef, right-clicking produces only a limited menu with no edit option.  If I right-click on the control and "edit", it's clearly not updating the typedef because when I choose "update from typedef", the changes go away.     I know I've done this before and I didn't have this problem.  What am I doing wrong?
(9,381 Views)
To update the Typedef you open it, make the change and then go to FIle -> Apply Changes and save the modifications.
Ben64
(9,372 Views)
But I can't make the change.  If I open the typedef, I just get a grey popup with the list in it.  Right-clicking on the list just has five options (2nd greyed out).  They are ""Reinitialise to default value", "CutData", "Copy Data", "Paste Data" and "Description and tip".   I've looked in the menu options, and I can't see any way to update the ctl file.
(9,368 Views)
Accepted by hc_ocean
Are you sure something that you are running ins't using the typedef?  I get this menu by placing an enum in a while loop and running it.
Bill
CLD
(Mid-Level minion.)
(9,363 Views)
That sounds a lot like you are in the Right-Click menu shown in red rather than either of the green menu options witch would open the items editor.
You don't want to operate on the data, you want to change the data type's items property.
"Should be" isn't "Is" -Jay
(9,357 Views)
It was that I had another VI open (but hidden) that also uses the same typedef.   Sorry to be a muppet.    I've "saved as" the new typedef, and I'm just trying to work out how to attach the new ctl file to the control.
(9,350 Views)
Find the old control and replace with the new one.  Use Ctrl+F to launch the object finder and have all callers in memory
(9,341 Views)
