trying to use the TIMER to work out how many mS there are between triggers
Hi all,
First of all, sorry for disturbing.  I tried to use the TIMER to work out how many mS there are between triggers, but I don't think I did it correctly so have a look and could you please guide me. I'm trying to read the TIMER when the trigger occurs and to save the value as "prev time". When the next trigger occurs, I read the TIMER and subtract the "Prev time" to see how long it took.
I set 10 Hz frequency trigger signal.
I also attached old version LV19 code.
Kind regards
Hasham
Message 1 of 23
(1,449 Views)
@Hasham622x wrote:
Hi all,
Kind regards
Hasham
try using a shift register and the 'first call' Boolean instead of local variables, like this:
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 2 of 23
(1,425 Views)
... and if you would use a globally initialized feedback node instead , you could eliminate the "first call" complication. 😄
Message 3 of 23
(1,393 Views)
 Hello @altenbach, well this was the best I could come up with for that. When I learned LabVIEW, I was taught to not use three things; Local variables, waits, and feedback nodes. Are feedback nodes really that bad? Maybe that was just the code style at that firm.
Message 4 of 23
(1,384 Views)
The first iteration will be off, but simple after that. Can just stick in the while loop. Can move t0 outside the loop if the first point is important.
Message 5 of 23
(1,378 Views)
The first point will be zero (not "off", whatever that means 😄 ), because no iteration has happened yet.
Message 6 of 23
(1,372 Views)
Off as in "Off the mark", not LED on/off. 🙂
From the dictionary
not accurate or correct : not achieving the desired result. Their estimates were completely off the mark.
Message 7 of 23
(1,370 Views)
Nice, so is the preferred over the shift register or just less clicks to get the same code functionality.
Message 8 of 23
(1,357 Views)
I think it is up to your preference, sometimes a shift register is easier, sometimes a feedback node is. The advantage of the feedback node in this case, is that the code can now fit on a "postage stamp". For some, that is preferable. 😉
Message 9 of 23
(1,355 Views)
First of all, thanks for your reply. I tried this shift register option, and it gives some random numbers, not actual time ...
Kind regards
Hasham
Message 10 of 23
(1,329 Views)
