timmer interrupt
Hi to all,
              I am makeing the program in that i have the num control if i put 2 it mean the interrupt will come after every two sec in between the program will do their process. How in comes i havn't find any timer interrupt.
(4,198 Views)
What are you trying to do over here? If you explain your application, we would be in a better position to help you out. Be sure to post your code as well!
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,190 Views)
hi adnan Z,
                 Basically i am communiation the labview with my controller i am checking all the parameters in the real time and also need to data log some of the parameters for that if i put the "Wait Until Next ms Multiple" then i can log the data after every 2 sec but with this my system is waiting for the 2 second and i unable to get the other patameters for that i need the timer interrupt after every 2 sec the labview enter into that function and conplete that process then again it come to the main function.
(4,180 Views)
Accepted by luthra_arun
I had slove the problem by using the "elapsed time".if there is any other method please tell so that i be update.
(4,170 Views)
Hi there,
I know it's been long time of this last post and it's also solved but, I'd like to ask you for the .VI file. The one you posted is from LabVIEW 9 and I still have 8.5. Could you save that file compatible with earlier versions or re-upload it in JPG or something like that? That could be very helpful forme!
Thanks so much!
(3,962 Views)
hI DiegoVS,
                 please find the attachment i had save in 8.5.
(3,951 Views)
Wow! Such fast reply! Thanks so much! It's very appreciated!
(3,934 Views)
