time tdms
Where would be the best place to insert this VI in order to have it fulfill this function?
Message 11 of 17
(1,973 Views)
Before you start the task.
Message 12 of 17
(1,972 Views)
I am not receiving this error: Error -200077 occurred at Property Node DAQmx Timing (arg 1) in DAQmx Timing (Implicit).vi:6520001->newtDMS1.0.vi.
Message 13 of 17
(1,968 Views)
Change the instance of the DAQmx Timing to be Sample Clock.  You can also specify a sample rate there if you want.
Message 14 of 17
(1,962 Views)
Unfortunately I am still having the same issue
Message 15 of 17
(1,955 Views)
I am still not able to have my DAQ timing clock run continuously and append that data to my TDMS file. The time is appending to file but only shows time values from 0 to 1 second. any idea what my issue is?
Message 16 of 17
(1,925 Views)
By default the Ramp Pattern VI is setting the "end" parameter as 1.  When I set it as 2 as seen in the included image, the TDMS file's time column goes to 2 seconds.  So, that is the part of your code that is causing the time column to only be written to 1 second.
Message 17 of 17
(1,902 Views)
