time management between objects
hello,
I notice a behavior with class containing wait fonction i don't expect
ie: i have to objects child of the same parent , both contain a wait ( simulating a wait for a device to respond  for exemple)
when putting calcul one after other it is normale to add times
but when both object are distinct i don't understand why times are added too ...
that let think that pause fonction are dependants ...
here a vi to test , the good one is "test para 2"
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,438 Views)
Make it reentrant?
Ben
(3,432 Views)
yes it works but i don't understand why they share a common timer without make it reentrant ...
do you mean its a normal behavior ?
may be i have to create a timer object ?
Regards
Tinnitus
(3,421 Views)
In fact it works for the little example but not in the big project where class1 is an element of other class ...
Regards
Tinnitus
(3,416 Views)
The behaviour I described for non-re-entrant VIs I posted in my Action Engine Nugget still apply in LVOOP.
So I would say this is expected behaviour.
Ben
(3,416 Views)
Hello Ben,
Thanks for the link,
The idea is the same except that AE is unique, with class we can have severals instances
but idea is the same
I agree with the property of non reentrant function and that a functionality i would preserve.( preventing race condition)
and making calc method reentrant break that ( the alocation of  different memory space is not enable with class method )
so two calc are done in 100ms with two differents object  but if i connect the same object twice in the loop this time while expecting a 200ms
(due to the protection ) it takes 100ms and that is not safe even if coding such a thing could not exist
To simplify
when 5 persons  run together during 10min the trainy take 10min                        // parallel tasks
if they  run a relay the total must be 50 min                                                       // serial tasks
and if we ask a person is to run  5 times 10 min he cannot do it in 10 min            // parrallel tasks serialized due to protection
Is there a way to obtain that
i will perform others tests tomorow ...
Regards
Tinnitus
(3,397 Views)
