Call a SubVi in Labview
I have a Main VI running. Now by pushing a Button, I wouldl like to open another VI or a SubVi.
How do I do that?
(13,607 Views)
Click on Help/Find Examples then go to Programmatically Cpontrolling VIs. Click on Dynamically Loading and Calling VIs and look for the Dynamic Load Example.vi
LabVIEW 2012
(13,604 Views)
Yes I have been playing with that example. But it has too many functions in it. I have used Labview about 6 years
ago writing Device drivers. But moved to Labwindows CVI and Visual C. I just want a very simple VI call
from another VI. To just have a button in the Main VI. By pushing the Button, the SubVi will come on.
I tried doing that by using Call By reference but not successfull.
(13,589 Views)
Accepted by topic author bobby_y
You may have a look at the attached VIs.
Nitzz
(Give Kudos to good Answers, Mark it as a Solution if your porblem is Solved;))
(13,577 Views)
why dont you use Event Case?
(13,575 Views)
With the help of SUB FRAME you can call any sub vi inside your main VI.. rachit kapoor www.rachitkapoor.leehoan.com
(13,573 Views)
Regards
Bobby
(13,536 Views)
