throbbing grey sequence
It worked great.  Then I edited some text on the front panel of a sub-vi and changed some default values.  Ran the main vi and the subvi bloc dia. pops out.  Things are clearly not working right.  I turned on the lightbulb to try and figure it out.  Everything outside of the sequence runs fine.  The sequence grey and throbbing.  What the F&&*&????????
LV 8.6 on Windoze XP
(2,693 Views)
Sounds like you set a break point.
Ben
(2,690 Views)
Thanks for the quick reply!!
(2,688 Views)
