Hello:
This is related to OAT Convert to Even Angle Signal VI. I would like to know how I can change the number of samples per revolution. I'm using "Even Angle Reference Signal Processing (Digital Tacho, DAQmx).VI" example and trying to modify this example for my application.
I have a shaft running at 180 RPM hitting an obstruct once at each revolution. Therefore, I need to collect as many samples as possible per each revolution to capture the transient signal. I tried all the combinations of Sampling rates, Number of samples (block size) ect. but when I check the even-angle reference signal, it has the same number of samples per each revolution.
I have NI 4472 DSA card to collect data, using NI 6601 counter to collect Tachometer pulses (720/rev). Attached Zip file contains a collection of modified VIs for my application.
At this point, I'm only interested in the "Even Angle Reference Signal". In other words, I would like to get the best resolution possible for a single revolution of the shaft.
Thank you very much.
