the meter (rotary control), how the scale can have color ramp, red on both ends
how can you have the color ramp on the scale of a meter (rotary indicator) to be red on both ends and green in a middle. i have tryed every possibility and i can only make it red only on one end. if anybody have any idea how to make it red on both ends, that will be a huge help. thanks
Message 1 of 8
(7,148 Views)
Accepted by topic author Mesay
You need to fiddle with the markers. It's not completely intuitive. You need to first turn off interpolation of the color ramp. Then you need to set the markers to arbitrary spacing. Then you can right-click on each marker and set the color within that section. Here's a page in the LabVIEW Help: http://zone.ni.com/reference/en-XX/help/371361B-01/lvhowto/changingthecolorsofacramp/
See attached example (LV 8.2) for a result.
Message 2 of 8
(7,135 Views)
You can also write to the Scale.MarkerVals[] property. It's an array of clusters where the first element defines the marker and the second element defines the color value.
Message 3 of 8
(7,131 Views)
Thank you very much it worked
Message 4 of 8
(7,120 Views)
a meter is a nice indicator. I always change its colors by setting two properties:  Scale.Interpolate Color and Scale.Marker Values[].
LV 9.0 example is attached.
Message 5 of 8
(7,099 Views)
Ljubo,
I love this idea but I'm not really sure I know how everything works since I haven't done much with the property nodes before. Is there any way to save your .vi back to version 8.2 so that I can access it?
Message 6 of 8
(7,056 Views)
Hi Scott,
I'm sorry but front panel screenshot is everything I can do now.
Regards.
Message 7 of 8
(7,052 Views)
That helps a lot, thanks!
Message 8 of 8
(7,047 Views)
