'Fuzzy System Designer' problem
After I completed set up the 'Fuzzy System Designer' (2 inputs and 1 output). How can I use it in vi program? I find it can save as .fc (custom pattern) file in 'Fuzzy Logic Controller Design'. But how to use the .fc file?
(2,731 Views)
To use the Fuzzy Logic file, you need to use the "FL Load Fuzzy Controller" to load the file and use the "FL Fuzzy Controller" VI to execute the controller.
The best way to see how to use it is accessing the manual and examples that ship with LabVIEW. You can access both function by going to "Help>>Search LabVIEW Help..." and go to "LabVIEW Modules and Toolkits" Options, browse the content for PID and Fuzzy Logic Toolkit. To access the example finder, go to "Help>>Find Examples.." and under Modules and Toolkits, find PID and Fuzzy Logic and open the examples.
Hope this helps!
Barp - Control, Simulation, RTT and HIL - National Instruments
(2,715 Views)
