temperature updating
I am new to labview an I have the code to get the temperature from a thermocouple sensor. But I was wondering how to make it the temperature update( not every second but maybe every minute) not is it just a simple loop? I'm confused. If someone could help me that would be great I attached the code below.
(3,088 Views)
to update temperature, encase the daq read in a while loop with included wait(ms), to hold the value every minute...put it on an initialized shift register, every minute(use an elapsed timer set to one minute) input the value to the shift register using case select, indicate value of the shift register...
(3,077 Views)
The first daq read should be encased in the while loop?
(3,058 Views)
Accepted by Gotti_uncc
If you want it to update continuously...
Spoiler
(3,049 Views)
Thanks I understand what you were saying now.
(3,030 Views)
