10-28-2013 05:13 PM
I have a SCXI 1000 chassis with two SCXI 1112 modules connected to them via two separate 6220 cards. I am trying to read a channel of each at the same time and it's not working. Only the first module works.
Any help will be appreciated.
Alex
10-29-2013 08:18 AM
Hello aavf
How are you connecting two DAQ cards to a single chassis? Are you using two 1349?
Regards
Frank R.
10-29-2013 12:10 PM
Each SCXI 1112 module has its own 6220 connected to it. The chassis can hold up to 4 different modules.
10-29-2013 02:21 PM
Aavf
I know the SCXI-1000 has 4 slots, I wanted to verify your set up. Even if you are using the 4 slots you could be working in parallel or multiplexed mode.
Well, it seems to be that you are using the connection described here: Parallel mode, and your module SCXI-1112 does not support that mode: Which SCXI Modules are Capable of Running in Parallel Mode?
Regards
Frank R.
