cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
system exec not running copy command
Resolvido!
Ir para a solução
zou,
I tried using a batch file but I get the same error that the file doesn't exist if I run the batch file using system exec.vi. If I double click the batch file in windows explorer then the command executes successfully and the file gets copied to the destination folder.
mikereporter,
If I use labview path control and use the browse path to system32 folder then I don't see query.exe(the file that I want to copy) in the results.
Mensagem 11 de 15
2.306Exibições
@LVCoder wrote:
zou,
mikereporter,
I wonder if this has anything to do with UAC?  I know LabVIEW has problems sometimes with UAC on at any level.
Bill
CLD
(Mid-Level minion.)
Mensagem 12 de 15
2.295Exibições
Solução
Aceita por LVCoder
My guess would be that your Windows is 64 bit and your LV is 32 bit and you're getting redirected. See here for a similar recent discussion with more details - https://lavag.org/topic/19387-system-directory-hidden-from-labview-not-really-a-labview-problem/
___________________
Try to take over the world!
Mensagem 13 de 15
2.268Exibições
Thanks tst! that exactly was the issue.
Mensagem 14 de 15
2.248Exibições
Wow, I knew you could trip over this issue with the registry - I didn't realize it applied to the system32 directory, too!
Bill
CLD
(Mid-Level minion.)
Mensagem 15 de 15
2.239Exibições
