switch executive in labview
Hello All,
I cannot find the switch executive functions in LabView.  I looked under both Function>Measurement I/O and Function>Instrument I/O with no luck.  I also tried opening the switch executive examples, but it says that "This example requires an add-on toolkit in order to run. The toolkit needed is not currently installed."
I am very sure that I have installed Switch Executive.  I can use it in MAX and I can also use it in TestStand.
LabView 8.6
Switch Executive 3.0
Message 1 of 9
(4,992 Views)
Accepted by topic author Bladhart
Try Sandra T advices.
post if still problem persists.
Message 2 of 9
(4,975 Views)
The problem lies in that I can't find the files nise.llb and niseCfg.llb anywhere on the computer.
Message 3 of 9
(4,955 Views)
In Sandra's post (linked by mathan) the next step was to repair the software.
Ben
Message 4 of 9
(4,945 Views)
OK.  I fixed it.
The problem was that Switch Executive wasn't properly installed, and the labview supports were missing.
Message 5 of 9
(4,937 Views)
Excellent!
Could you please mark mathan's post as the solution to help other when they run into this same situation?
Thank you!
Ben
Message 6 of 9
(4,918 Views)
Hi, I'm having the same problem with Labview 2010 and Switch Executive 3.0. I tried reinstalling and have had no luck. It is registered.
Message 7 of 9
(4,324 Views)
Hi Nickkkk,
This is a known issue with Switch Executive 3.0 and version of LabVIEW newer than 8.6. Here is a guide to getting the VIs to show up in LabVIEW 8.6 and newer (including 2010):
KB - 52JDQSHL Switch Executive 3.0 Does Not Install Support for LabVIEW 8.6 or Later
Steven K.
Software Engineer
Message 8 of 9
(4,295 Views)
Thanks, that worked the second time I did it. It helps to select "Modify", not "Repair"  🙂
Message 9 of 9
(4,291 Views)
