suspend when called
When I suspend the execution of a VI using the "suspend when called" property, is there any way to tell which VI called the suspended VI? Thanks.
(3,301 Views)
guessing...
Take a look at the indicator on the tool bar where you normal expect to see the font drop-dwon menu. Does it show the call chain?
Ben
(3,299 Views)
Accepted by efarr
There is a function that returns the call chain.
Also you can use the trace execution toolkit for lots of low level executoin detail
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,298 Views)
The VI hierarchy is on the menu! Thanks!
(3,291 Views)
I'll take that as a sign that it is on the drop-down menu as I had guessed.
Ben
(3,282 Views)
