string reference adding to indicator
How do i prevent the "Serial Data" indicator from being emptied/cleared every time i use it?
( want to see the "Serial Data" in real time)
/J
(4,741 Views)
Hi std,
From your image: the string indicator never gets cleared - atleast not in this image…
(Why do you use a reference and property nodes when the terminal is still available?)
To answer your question: when you don't want to clear/empty the indicator you should not write an empty string into it…
(4,717 Views)
Hi GerdW
If you run the attached VI you will see that that the "Serial Data1" is erased when "Serial Data2" is written.
The picture is an example code. The 2 Sequences are instead of my Serial communication SubVI that writes and reads data from the serial port and the reference is there to be able to see the serial communication in "realtime".
So i want to add all serial data to the indicator "Serial Data" (want it to work like a terminal app would).
(4,702 Views)
Hi std,
unfortunately I cannot open your LV2015 VI right now, I'm stuck at LV2014…
But I guess it's the same as is shown in the image above: "serial data1" is not "erased", it's overwritten!
So you want to concatenate all string data into a huge string?
Then you should use the ConcatenateString function and a shift register as you should have learned in the LabVIEW beginner courses offered for free by NI…
(4,696 Views)
Sorry, Yes it is overwritten.
You are right a Concatenate string function and a shift register fixed it(with an Event Structure in the mix).
I probably forgotten or, have dozed off during the course...
(4,658 Views)
Accepted by std
Use the "Append String" method.
(4,642 Views)
