string or hex number split/divide in same number.
hello this is not working, Im getting random values..
let me explain the my conditions again, there should be only 4 cases as i have only 4 conditions.
if
N< N1 then case 1 should execute,
if N> n1 and less than n2 then case  2 should execute,
If N>n1,n2 and less than n3 case 3 should execute,
If N>n1,n2,n3 last case 4 should execute.
inside the case im performing some mathematics operations.
Message 21 of 27
(1,178 Views)
Hi new123,
@newmemeber123 wrote:
if
Try this:
Keep in mind: LabVIEW (like any reasonable programming language) starts to count ranges at zero, so you get cases 0…3 (instead of 1…4) for 3 nx values…
Message 22 of 27
(1,166 Views)
its showing threshold error array with bad terminal i know why its showing like that. now all the values are scalar not array because i removed previous error i was using indexing tunnel not previous value thats why it was giving output as a array not scalar now its giving scalar.
is there any example if the values are scalar not an array?
Message 23 of 27
(1,156 Views)
if
N< N1 then case 0 should execute,
if N> n1 and less than n2 then case  1 should execute,
If N>n1,n2 and less than n3 case 2 should execute,
If N>n1,n2,n3 last case 3 should execute.
Message 24 of 27
(1,141 Views)
Accepted by topic author newmemeber123
Hi new123,
Is it really this complicated to adapt my suggestion to your "only scalar values" requirement?
Really???
(Do you really need to post your requirement again in a new message?)
Message 25 of 27
(1,138 Views)
The solution I posted earlier does exactly what you are asking. I don't see why you are struggling this much when several correct solutions have been posted.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 26 of 27
(1,117 Views)
its working now. thanks
best regards
Message 27 of 27
(1,092 Views)
