string or hex number split/divide in same number.
hello everyone,
im receiving 12 character string from the sensor which is changeable after every read( For example ) 04C613E81E00. i just want to divide it separately in three equal part such as 04C6, 13E8, 1E00(1st part 04C6, 2nd part 13E8, 3rd part 1E00). can someone tell me how to do it? i tried with split string but as it is changeable data im not able o do it with split string.
Thank you in advance 🙂
Message 1 of 27
(4,016 Views)
Hi 123,
What have you tried with SplitString that "does not work"?
I recommend to use ScanFromString with a format string of "%4s%4s%4s":
Message 2 of 27
(4,014 Views)
thank you so much. i tried the same %4, %4,%4 was missed, silly mistake thank you
Message 3 of 27
(4,002 Views)
Or if you need numerics in the end...
Message 4 of 27
(3,978 Views)
Thank you both. its working.  I have another question i have converted these numbers to decimal and i have to compare these three number with another decimal number separately with less than sign and if it is less than it then that case should execute.... should i use the the case struct or something new you will suggest? because it is showing error while i use case structure.
screenshot is attached of my try.
Message 5 of 27
(3,966 Views)
When you compare one array to another, you get an array of results.  You cannot use an array of results for your case selector.
Bill
CLD
(Mid-Level minion.)
Message 6 of 27
(3,964 Views)
thank you.
can you suggest me please? How can i compare these numbers and if they are lesser other then next condition should execute.
looking forward to your help
thank you 🙂
Message 7 of 27
(3,958 Views)
thank you.
thank you 🙂
You should probably have 3 case structures.  Depending on what is happening in them, you could use a FOR loop to only execute the case if that value is less, using the i terminal as an input for whatever is happening inside of the case structure.
Message 8 of 27
(3,951 Views)
thank you..do you have a similar example ? or link of similar example?
Message 9 of 27
(3,922 Views)
What are you actually trying to do with these case structures?
Message 10 of 27
(3,916 Views)
