string array next items
Should be simple but don't see how it can be done.  A 1D string array control the user wants it to advance to the next item in the string wehn either tab or enter is presses.  I don't see anything in the property node to control the active item.  Any suggestions?  I was thinking of giving them a text box and populating the arry for them.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,407 Views)
Hi Matthew
i think this should help you.
Mike
(3,394 Views)
All, answering my own question.  Enable SkipTabbing.  This is only available using a properity node.
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
(3,350 Views)
