click and drag offset
Is it possible to make a feature where you can click and drag a curve in a graph widow to adjust its offset?
(2,617 Views)
I have seen example where this was done using a picture control.  No, I don't believe this could done using a graph control.  Using an XY graph you could add a circle but probably not using the mouse.  Use other controls like radius on location to move is around.
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
(2,602 Views)
