How to trim white space and move string position
Does anybody can help me out, I tried to trim white space and move
string to begining of each line, example:
Text file: " AAA "
" BBB CCC "
How do I output them as: "AAA "
"BBB "
"CCC "
I had tried Trim Whitespace.VI + other Scan string function but not
getting nowhere.
Thanks for help.
(5,584 Views)
(5,576 Views)
Trim white space node works for me.
I also tried Dragon64's example, it works too.
If all you want to do is get rid of the spaces in front of one string
Hope this helps
Message Edited by Van_L on 02-19-2008 10:44 AM
Van L
NI Applications Engineer
(5,551 Views)
You can do a Search and Replace, find the space constant and replace with a space constant concatenated with a carriage return constant
edit - you'd need to ignore the cases where you already had a space-CR, though
Message Edited by JeffOverton on 02-19-2008 11:52 AM
(5,541 Views)
> <img src="http://img137.imageshack.us/img137/1591/replaceef1.png">
> &nbsp;
> edit - you'd need to ignore the cases where you already had a space-CR, thoughMessage Edited by JeffOverton on 02-19-2008  11:52 AM
Thanks for helping. I click on <img src="http://img137.imageshack.us/
img137/1591/replaceef1.png"> but nothing there.
(5,515 Views)
It's just a picture of the wire diagram.  Those VIs are both in the String palette, and they are called Concatenate Strings.vi and Search and Replace.vi
(5,502 Views)
