stop during aquiring
Dear sir,
I would like to stop the aquiring application during aquiring (aquiring interruption).
Thanks so much for your efforts
eyad
automation engineer.
(2,552 Views)
Presumably, your acquisition would be in a loop and a front panel Boolean would be wired to the loop's conditional terminal so if you have something more complicated than that, you are going to have to do a lot more explaining. Image of the block diagram or the actual VI will help.
(2,549 Views)
A very simple solution to your problem, assuming I understand it correctly:
Put your aquisition in some kind of a loop, that is started/stopped by a boolean control (aka a button).
Then, when you want to stop aquiring data, press the button.
Cory K
(2,539 Views)
