specifying file name
How do I specify a file name when using the Read Binary File vi? It looks like I would use the file (use dialog) input to specify the path and file name. How do I do this exactly? TIA.Smiley Sad
jlivermore
(2,722 Views)
You need to type the full path name, for example:
C:\Documents and Settings\My Documents\File.txt
Or what I usually do is have the following
Constant -  " C:\Documents and Settings\My Documents\ "
Control - Input the file name
Constant - " .txt "
Then I concatenate those strings and convert to file path.
That way, you don't have to remember the full file path, just the name of the file.
Cory K
(2,710 Views)
Thanks, Kory...I'll use your suggestion.Smiley Happy
-jlivermore
(2,705 Views)
