cRIO 9004 web server
Hi i need to create a web-server for the cRIO 9004 is there anybody that can help me?
i don't know what i have to do and what i have to set.Plz help me
Message 1 of 15
(6,048 Views)
i mean are there some instructions that i have to follow to create a webserver?
tnx really really tnx
Message 2 of 15
(6,037 Views)
so?plz nobody can help me?
Message 3 of 15
(6,027 Views)
Hi Salvio,
Do you mean how you can publish your VI to the WWW or to create an webserver with HTML pages?
Watch my spaghetti cRIO webserver in the attachment; I have used thisone some time ago.
There are some examples on TCP on the NI website or in the LV help.
Kind regards,
Message 4 of 15
(6,019 Views)
ok i'll try it. do u have an e-mail where i can write to you for more information or other problems on this webserver?
really tnx
Message 5 of 15
(6,012 Views)
Salvio,
Here are some links related to using the web server in LabVIEW. What specifically would you like to do in your application using the web server?
https://www.ni.com/docs/en-US/bundle/labview/page/enabling-and-configuring-the-web-server-for-remote...
https://www.ni.com/en/shop/electronic-test-instrumentation/programming-environments-for-electronic-t...
In LabVIEW also take a look at the menu Tools>>Web Publishing Tool...  This will step you through developing a web interface to your application.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 6 of 15
(6,011 Views)
i've to use it like a remote controll. is there some application that i've to do to make it works?
Message 7 of 15
(6,008 Views)
That Use Case sounds like the Remote Front Panel in LV RT. Look for topics relating to 'Remote Front Panel' on DevZone and in the product documentation.
In LabVIEW go to the Tools>>Web Publishing Tool... and select Viewing Mode 'Embedded'.
authored by
Christian L, CLA
NI - Austin, TX
Message 8 of 15
(5,999 Views)
Ok today i'll try to make it works. I'll make you know if it works.
Tnx for the help.
Message 9 of 15
(5,992 Views)
i've got some problems...i've tried to follow the steps of the first link you have given to me...but i don't know why it doesn't work.
please,can you see if i've understood what i have to do in every steps?
for the first three steps i've done in this way:
1-2 of (1-2-3-4-5-6)- i've opened the VI that i want to see on the web, i've clicked on TOOLS, then to proprieties and then i've clicked on WEB server:configuration...i haven't undestood when it say right click the target in the project and click on proprieties..i don't see them on labview 8.0...
3-4-5-6- i suppose that i've done right because i went into my project on build specification and i've created the real-time application and i've build it then i've  set it as startup and then i've deployed it.
7-i've reboot my cRIO
8...and so on- i don't understand these point because i think that i've done them before but  i've done them same and  as i've told before the application doesn't start Smiley Sad
please help me
Message 10 of 15
(5,973 Views)
