status
Just to throw in my $0.02, you are giving a non-Excel file a .xls extension.
Don't do that. Please don't do that.
PaulG.
Retired
Message 21 of 41
(1,700 Views)
Hello
WHat do u mean by dont do that sir
Any other option
Message 22 of 41
(1,685 Views)
Save the file with a .txt extension or create an actual excel file with ActiveX properties and methods.
Before starting your project, you should have asked for help in the design. Choosing a text file format, in my opinion, was a mistake. If you had used an actual database or Excel file, you wouldn't be hacking your way through the mess of code you now have. I'm not sure why you won't answer some of the questions that you have been asked or take the advice you've been given.
Message 23 of 41
(1,678 Views)
Hello sir
I have been going through everybody comment and try my best to understand what i can do and implement in my project.
My supervisor does not allow me to store in notepad ( text file). I have to use excel to do so.
I came across this VI which i found interesting and was one suggestion from the above members. but i dont know how to modify
and implement this in my project
 refering to this link
http://lavag.org/topic/15034-timestamp-support-for-format-into-string-scan-variant-from-string-strin...
I am not able to attach and post the VI. it is within this link
Message 24 of 41
(1,655 Views)
You can't store stuff in notepad.  Notepad is an application intended to open and save text files.
Your supervisor says you can't store stuff in text files, but that is exactly what you are doing when you use Write toSpreadsheet File and Read from Spreadsheet File.  Giving it an .xls extension doesn't magically turn it into an Excel file.  It just makes it a text file that has an inaccurate extension which is why you should'nt name it .xls.
I have no idea how that link to the Lava thread is supposed to help you with your problem.
Message 25 of 41
(1,650 Views)
Seems to me to be artificial constraints - kind of like a homework assignment or a test.  In this case, you would fail for the reason mentioned multiple times before: you have a text file, regardless of the extension you give it.
Bill
CLD
(Mid-Level minion.)
Message 26 of 41
(1,641 Views)
Thank you all for your advice. I shall recheck myself onto the coding.
Thank you. i did learn the technical term here
thanks all.
Message 27 of 41
(1,621 Views)
hello everyone
referring to each comment, i try to reset my aim on the status
which mean if due date arrives, notification should be pop out..
however since 7 days were given to the student, i make the coding like this.
but in some i am getting error and i dont know hw to test it..
is it correct.
Message 28 of 41
(1,606 Views)
Quite frankly, none of that makes any sense to me. It looks like you have completely ignored the advice that I and others have given you.
Your main VI still has not been provided. You are reading from one file and writing to another. If your main truly has a checkout state, the new status would always be 'checked out'. Pointless to check if it is overdue. The file with the status and due date (which is the only file you should be reading/writing), does not have a time for due date, only a date. Your main should only check for overdue items once a day. If an item is not overdue at 1 am, it won't be overdue at 1 pm.
Your coding is questionable as well as the overall design. You need to make some fundamental changes and provide the information that has been repeatedly asked for.
I've spent way too much time saying the same things over and over again and being ignored. I can't help any more. Good luck.
Message 29 of 41
(1,595 Views)
Dear Sir,
i appreciate your help. I dont thnk i ignore. refereing from the start of this conversation, mostly discussion was
in term of the format how i store my data, delimited txt, .csv or by excel.xls
Dear everyone, i am stuck in this VI that why i am slow to understand each meaning as all members have different point of view
I am unable to upload my whole VI here, when i am uploading, it is saying error...
I apologise if i didnt follow some guideline. i am just trying to understand but all point of views are different..
But thanks if somebody here can give me with a sample Vi, this will help. I was about to follow a course but with limited time , i am
not able to do so.. This is why there is many thread of my question you will see because i still cannot solve
But i will try my best even though.
Message 30 of 41
(1,573 Views)
