06-26-2014 07:44 AM
Just to throw in my $0.02, you are giving a non-Excel file a .xls extension.
Don't do that. Please don't do that.
06-26-2014 09:03 AM
06-26-2014 09:16 AM
06-26-2014 05:12 PM
Hello sir
I have been going through everybody comment and try my best to understand what i can do and implement in my project.
My supervisor does not allow me to store in notepad ( text file). I have to use excel to do so.
I came across this VI which i found interesting and was one suggestion from the above members. but i dont know how to modify
and implement this in my project
refering to this link
I am not able to attach and post the VI. it is within this link
06-26-2014 05:18 PM
You can't store stuff in notepad. Notepad is an application intended to open and save text files.
Your supervisor says you can't store stuff in text files, but that is exactly what you are doing when you use Write toSpreadsheet File and Read from Spreadsheet File. Giving it an .xls extension doesn't magically turn it into an Excel file. It just makes it a text file that has an inaccurate extension which is why you should'nt name it .xls.
I have no idea how that link to the Lava thread is supposed to help you with your problem.
06-26-2014 05:30 PM
Seems to me to be artificial constraints - kind of like a homework assignment or a test. In this case, you would fail for the reason mentioned multiple times before: you have a text file, regardless of the extension you give it.
06-27-2014 01:51 AM
Thank you all for your advice. I shall recheck myself onto the coding.
Thank you. i did learn the technical term here
thanks all.
06-27-2014 08:07 AM
hello everyone
referring to each comment, i try to reset my aim on the status
which mean if due date arrives, notification should be pop out..
however since 7 days were given to the student, i make the coding like this.
but in some i am getting error and i dont know hw to test it..
is it correct.
06-27-2014 08:37 AM
06-27-2014 12:33 PM
Dear Sir,
i appreciate your help. I dont thnk i ignore. refereing from the start of this conversation, mostly discussion was
in term of the format how i store my data, delimited txt, .csv or by excel.xls
Dear everyone, i am stuck in this VI that why i am slow to understand each meaning as all members have different point of view
I am unable to upload my whole VI here, when i am uploading, it is saying error...
I apologise if i didnt follow some guideline. i am just trying to understand but all point of views are different..
But thanks if somebody here can give me with a sample Vi, this will help. I was about to follow a course but with limited time , i am
not able to do so.. This is why there is many thread of my question you will see because i still cannot solve
But i will try my best even though.
